Mjolnir
- Joined
- Dec 19, 2008
- Messages
- 1,711
I recently "built" a 2D ROP maglite using 2 LiCo 18650s. I am planning on getting 2 4000 Mah 26650 LiMn (or IMR) cells from batteryspace. Apparently these will not destroy the 3854 low bulb, but their higher voltage off the charger will kill a 3854 High bulb.
One option would be the 7.2 Volt 3853 high bulb, but since it will not be overdriven as much as the 3854 would be, it wouldn't be as bright as a normal ROP high.
Apparently the Osram 64430 can stand up to the voltage. However, according to LuxLuthor's desctructive bulb tests, the estimated lumens are not very high for the 6-7 amps that the bulb is drawing, especially when compared to the 3853 High, which apparently draws about half the current at a given voltage, but has similar estimated output.
Also, my current reflector only has an 8.3MM opening. I am fine with getting a Bi-pin socket, but I'm pretty sure that many of the potential bulbs will not fit through the opening. However, the pins might, so is it practical (or recommended) to use a reflector with a small opening with a bi pin bulb (where the bulb body itself can't actually fit through), or is this a bad idea? I would hate to waste a perfectly good reflector, although I will get one with a wider opening if it really is necessary.
Are there any other bulbs that I should be considering for output equal to or greater than an ROP high bulb? I would like to keep the current draw under 10 amps, since that seems to be the limit for continuous draw for the cells. Also, it needs to withstand the voltage from 2 IMR cells fresh off the charger.
