OK back again with another question.
What would be the shopping list I would require to use my 6D as a host and run the 64430 at close on 11V?
- Batteries (see below)
- Kiu socket kit
- Some sort of switch upgrade
- Better reflector, lens, etc., if you like -- there's always ways to make a light more expensive!
The stock Mag switch is generally considered to be good up to about 5A. If you need a little more (as in your case), you can modify it a bit to reduce resistance (and thus heat generated in the switch), you can convert it to use a MOSFET to switch the bulb current, or you can rebuild it, typically with a rocker switch. You can also run it till it melts, then decide what to do with the new one -- and at only 8A, it may actually last quite a while.
You could also look at getting a regulated driver from AlanB -- costs a bit, but how can you put a price on continuous white light for the whole battery life?
This would replace the Kiu socket kit.
There are obviously lots of battery options, which would be best for this voltage to maximise runtime in this host? The use of dummy cells always kinda annoys me so would prefer to avoid it.
Well, if you're direct driving, you need 9 cells NiMH, or 3 cells Li-ion (LiCo or LiMn chemistries, anyway). Don't know of any Li-ions that make that real easy while utilizing the whole tube, and of course you should read up on them and their dangers before you go that route anyway.
But the "obvious" solution is 9x
1/2D NiCd. Yeah, you'll need a 1/2D spacer, since 5x 1/2D = 3xD, but don't get hung up on that -- all the 3-stack configs wind up wasting more space around the edges than that spacer does at one end. This gives you 10.8V at 2.5Ah.
If you spring for a regulated driver, all you need is
more than 11 V, so 10x 1/2D NiCD would work great (12V x 2.5Ah = 30Wh, and good for up to 500W or so into the right bulb). Alternatively (and this would be my preference) you could stuff the tube with 4x
F (32900) LiFePO4, for 12.8V x 4.5Ah = ~60 Wh, and up to nearly 1kW.
If you do this, you'll need a good
balancing charger, or four single-cell chargers; while these won't explode like LiCo, you still risk wrecking your battery if you try to blindly series-charge it, so be
sure you know what you're getting into...
Been searching for Kui sockets but dont know if something like this is still available?
Kiu, not Kui -- they're
here.
