Barbarin
Hi guys,
I'm in Paris, in Eurosatory show... This is what I have seen there.
Wonder how they compare to the standard headlamps... Also wonder how they handle heat sinking during long periods of idling.
Weirdness. Don't forget to not hotlink, tho.Hey, great link. I was able to work around the linked site's faulty coding and snag this large image:
I'm not to thrilled as to what the photometry would look as your considering multiple emitters
The front cover is made of clear Polycarbonate - no matter the quantity of UV additive in the original resin, in desert conditions it will quickly become yellow and brittle. Sand, wind, and total dry environment act like a sanpaper on the hard Polycarbonate headlight's lens which will become a primary source of disturbance to other drivers.
in this extermely hot environment any heat sink will become a heat accumulator.
I think is a mistake to look at the vehicle's mass of metal as a large heatsink.
It is known that at a given constant current the LED's output is influenced by the environment's heat. The output decreases when hot and increases when cold. That means that if the same hummer will be relocated in Alaska, the headlights will be almost 160% brighter! I see that the headlight has the DOT mark on it I wonder how it passed the SAE tests.
Anyone has an idea if they are used in real life or only assembled on a concept vehicle for show?
I see some 10 LEDs in this headlight. This setup needs separate LEDs for the high beam and low beam. Assuming the minimum 800 lumen needed to produce a relatively medium intensity headlight (although 1000-1100 lumen is the common 55W halogen)
From the photo it is not clear if the heat sink fins are horizontal (which is a wrong design) or vertical.
Based on my experience with such vehicles and desert conditions dust will accumulate quickly between the fins. Desert dust is like powder and combined with little humidity it clogs and is very hard to remove even by air ventilation.
Regarding the lens, military guys are inlove with polycardonate, this is right - the lamp was probably designed to some spec provided. But a 5 in. diameter or more
I see 3 wires entering the lamp, probably common gnd, hi and low beam. In the company's website there is a separate controller needed
What I say in such situation, based on my 10 years of experience with LED technology is "let's wait an see"
