... i used them all 4 together in my ledlenser p7.2...<snip>
OK, so now I know how you will use these cells, so I can try to give you some more information. (I believe my information is correct, but others are more battery expert than I, so they may have different or better advice.)
So, first let's talk a little bit about what happens when you use 4x Eneelops together. (By the way, the LED Lenser P7.2 looks like a very nice flashlight!)
Your four cells: A, B, C, D each put out about 1.2v and I assume they are connected in series so total voltage is 4.8v to power the LED emitter. In the beginning, all four cells have plenty of energy (mAh), but as you use them, both their voltage and mAh is reduced. The problem may occur when one cell ("A") loses all of its energy before the other three cells. If energy of cell "A" goes to zero (completely dead) then the other three cells ("B," "C," and "D") may work together to "reverse charge" the cell "A."
Such "reverse charging" is very bad. In some rechargeable cells (like Li-Ion) or even some non-rechargeable cells (like CR123A) this can result in intense heat, release of poisonous gases, and even explosion. In the case of NiMH rechargeable cells (Eneloop) there are no safety risks that I know of. (I do not believe your Eneloop cells can ever explode.) But, I believe that such "reverse charging" can damage or destroy your Eneloop cell, so that you must replace it.
So, if you follow my description of the problem, then you can see that the simplest solution is to never drain all the energy from your "weakest" cell. In other words, if there is always enough energy (mAh) left in your cell "A," then your other cells will never try to "reverse charge" it. The benefit of matched cells (cells that contain as close as possible to the same amount of energy in each one) are that they can be safely drained down to "zero" or near "zero" (completely dead). In reality, this is usually only important in the "Hobby World" such as RC car racing. If you race RC cars, then having an excellent "matched" battery pack, can help you win races. But, for flashlights, I guess it is usually not so important.
In fact, since voltage is also being reduced as energy is being reduced, I think there is good chance that your LED Lenser P7.2 may stop working (due to low voltage) before your cells can ever be completely drained. (I believe that this is a common feature/design of many good LED flashlights. But, I do not know enough about your flashlight to say whether or not this is true. But, I think it is likely.) In my case, I worry a bit more about having "matched sets" because I use many of my AAA Eneloops in very cheap "emergency" flashlights which probably do not have such complex circuitry, so I believe that they can probably use all the energy down to zero (LED just gets dimmer, and dimmer... as the voltage gets lower and lower.)
So, for now, my suggestion is to use your Eneloops in your flashlight, but recharge them before they are fully drained. (I believe your flashlight gets about 4 hours run-time on regular high mode, and 2 hours run-time on "boost" mode. So, try using it for only about 3 hrs. on high, or about 1.5 hrs on "boost.") Don't worry, this is not a permanent restriction. It is just my recommendation while you attempt to break in your troublesome cell "A."
...i noticed that it stops charging ahead of time while others are still charging there's a long time delay between the cell B...<snip>
When you remove your cells from your flashlight, fully discharge them in your MH-C9000. Your MAHA will drain all four cells "completely" (or down to the "best" level), but this is "safe" because your MAHA is treating each cell differently in its own individual circuit. That is why you noticed above that your cell "A" stops charging a long time before the cell "B." It has less capacity, so it takes less time to charge. This is completely normal.
But, hopefully, as you use your cells in your flashlight this way, you will begin to notice that the capacity of cell "A" begins to improve each time you recharge it.
If it does not begin to improve, then eventually you may wish to try the time consuming "BREAK-IN" procedure, or perhaps even multiple "CYCLE" procedure. But, I understood from your posting, that you wished to avoid such time consuming procedures, and enjoy your LED Lenser P7.2 immediately. So that is why I suggest just using your cell for a while, and see what happens. (It should be no problem at all to use your cell "A," so long as you do not "over-discharge" it while connected to the other three cells, as I explained above.)
