Re: If you could only own 1 flashlight for the rest of your life.....
It would probably be a McGizmo Ti-PD updated with an XM-L. (like the one I have
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Reasons:-
Reliability
- Ti is strong, durable, doesn't corrode even in salt-water, is more than a good enough conductor of heat/electricity for a high level of 525ma
- mechanical switch mechanism with piston contacting kilroy spring I perceive as being more reliable than electrical switch mechanism and more reliable than clicky switches.
- McGizmo doesn't know how to make an unreliable light!!
Form/function
- Fits the hand beautifully
- Flutes on the head perfect for engaging the tips of the fingers into for rotation
- UI is KISS and completely intuitive with the push lightly for momentary low, push harder for momentary high, twist a little for constant low, twist more for constant high
- Tailstanding is as solid as a rock. Nothing is going to topple it over.
- Clip perfect for carrying in a pocket and also functions as an anti-roll device. New clip design can be used to screw into tripods and other accessories.
- Tritium at end of piston helps to locate light at night. Also a slight bit of bling but not too over the top.
- 525ma on high allows for over an hour of runtime for a small, pocketable EDC, yet with an XM-L its still more than bright enough for most tasks
- Low level is spot-on for preventing night blindness and allowing for easy nocturnal navigation round the house without rousing sleeping partners and kids
- Beam is perfect blend of spot and throw
- Water proof and probably dive proof, bomb proof and EMS proof.
Aesthetics
- Damn good. I still enjoy looking at it after all these years.
