Have you guys noticed the Cree datasheet and the curve for the Intensity vs. Current? A while ago (a few months), the line flattened out as the current approached 1A. I went ahead and hosted some snippets from the datasheet:
The first was from around May, I believe, while the second is the latest from this July. I was shocked when I first noticed this! I was excited to see this straighter line. This means more lumens at a higher power. Now, is this because the LEDs produce less heat, or because they are starting to create some sort of "anti-droop" technology like what Lumileds claimed to have? If it is because of less heat, then this current datasheet would be useless for the older, less efficient P-binned XR-Es. Hmmm...
I still need to compare the "Photometric Output vs Junction Temperature" to see if those changed. It is a good idea to hold on to older datasheets. It is fun looking back.
I, too, cannot wait untill Seoul P4s start using these more efficient dies. The phosphor they use seem to be more sensitive and efficient, so this change would be amazing. Plus, you got the well-focusable lambertian dome! Oooh, I forgot that tint shifts (for those who experienced them) will improve due to the less heat. Yipee!
I created an Excel worksheet comparing the intesity vs. current curve from the datasheet, from Newbie's findings, and another source (A chart made by another CPF member -was it you, jtr? I don't remember). From the "multipliers" (that curve -compared to the lumens at 350mA) were used to estimate the lumen output with the different, newer Cree XR-E bins. I will have to post it sometime if anyone wants it. The curves are pretty close to each other, but this new Cree datasheet set things apart again. I will have to add a new line on the chart using Cree's older specsheet. It would closer resemble Newbie's findings.
I was able to estimate (or predict) the lumen output at currents above 1A. Boy is that impressive! Sure, Cree and everyone else says that you should not "go over 1A". Newbie did the test up to 2A and things went fine for him. Actually, the numbers he got (lumens) at currents over 1A was used in my graphs. I want to do long term overdriving tests once I get (can afford) a good lab power supply, and a light meter (some day).
-Tony
