DimeRazorback
Re: Got my JETBeam RRT-0 Today
Hmm it seems that some of the things I was skeptical about became fact
For how long? Intuition tells me it will only get looser as time passes.My selector ring is nice and firm
cant wait for mine to arrive
Cool...thanks for the review and pics so far! :twothumbs
I can't wait for you to post some outdoor beamshots. How would you say the build quality is compared to an E1B? How do the threads feel in comparison?
Thanks,
Robert
There is some more information about the strange level behavior based on battery usage in this CPFMP reply. I was considering getting one until I read about this "feature". Especially the part where it says "Users should use fully-charged or fresh rechargeable Li-ions, and should not turn off the light in the middle of continous use, or the circuit may have wrong estimation of the battery type." What exactly does that mean? If you're using Li-Ions or rechargeables you're not supposed to turn the light off once you've turned it on for more than a few minutes or the flashlight will get confused? :shrug:II cannot get any (have tried 10 of them) of my Made in USA Energizer e2 Lithium CR123's to work. They either stay in low mode, or go to the high mode and then cut out, or get to the high mode and stick there. Very inconsistent behavior. This makes me sad, because I really, really like this light. :mecry:
I take it to mean that if you have a Li-Ion that has low voltage (3.2v or less) and you use the light (dropping the voltage further) then shut the light off and on, the light's circuitry may treat the battery as a primary and not go into light-circuit protection mode when the voltage drops further. This would be dangerous behavior if not using protected cells.There is some more information about the strange level behavior based on battery usage in this CPFMP reply. I was considering getting one until I read about this "feature". Especially the part where it says "Users should use fully-charged or fresh rechargeable Li-ions, and should not turn off the light in the middle of continous use, or the circuit may have wrong estimation of the battery type." What exactly does that mean? If you're using Li-Ions or rechargeables you're not supposed to turn the light off once you've turned it on for more than a few minutes or the flashlight will get confused? :shrug:
I think I'll wait a little bit until more is known about how the electronics in the RRT-0 work in the real-world.
