My M2XC4 was waiting for me at home today when I came home from work (YAY)!! I ripped open the box and took a look inside....we had the light, a holster, lanyard, 2 plastic CR123 tubes, a battery holder with switch, 2 spare O rings, and the switch cap. The light itself is heavy and appears to be very well made. The head is heavier than the body, and the body is relatively lightweight. I also had 2 Eagletac 18650 protected batteries in the box, and they tested at about 3.7v. I put them in the charger and at first the charger would not turn on. It is working now, but this is a slight concern. I put 4 Pentagonlight CR123's in it just to test it in my back yard. I pitted it against my Tiablo A9, which was my brightest light up until today. It seems to be about 2x as bright as the Tiablo, with both lights on high. I will test it with 18650's tomorrow. I was going to put the included clickie switch on the light, but the switch is plastic and appears flimsy and not very good quality. I also would not trust the lanyard connected to this plastic switch as it looks like it would break easily. The battery carriers also are a bit on the flimsy side, and I hope they do not break. The light appears useless without them. Oddly enough, I did not have the problem most people seem to be having with the ring selector. I had no problems turning the light on/off, or going from low to turbo.
Mike
Mike
