Knurling on flashlight bodies...more or less grippy?
ateallthepies
Rickmansworth, U.K
As the title says, does knurling make a light more or less grippy?
My very unscientific experiments lead me to believe most knurling reduces surface area and makes for less grip. Unless the knurling is aggressive enough to actually get a mechanical hold on the skin, is it worth doing?
Steve
El Camino
I would say yes. I'd say knurling increases surface area. Skin is elastic, so when griping a textured surface, it will mold to that surface. This is why you sometimes get imprints on you hand after holding something tight. Some people go a set further and add rubber grips, or make one with paracord. In my experience, smooth objects, including lights are harder to hold.
Dances with Flashlight
Glendale, Arizona
Not too scientific, but knurling can vary so greatly that there may be no simple answer. An aggressive, sharp knurling is certain to provide for greater gripping effect, unless it's so sharp that you can't comfortably hold it and prefer to let go rather than risk flesh. However, a light knurl may as you indicate so reduce surface area that gripping is less sure. Polishing a lightly knurled surface to the extent of rounding may further reduce its co-efficient of grippinessability or whatever.
Echo63
Perth - West Australia
Even the old worn knurling on my old minimag is easier to grip with oily hands, than the smooth metal beside it.
Lone of my EDC lights has a really nice flat topped knurl that is nice to hold but not too agressive
the other has a series of ridges around the light
both work to hold onto the light, but the knurl is better if you are trying to twist the light
PCC
Sitting' on the dock o' The Bay...
You can try a simple test: take a 3D or longer MagLite, complete with batteries, and hold it in your hand by the knurling. Standing up, drop your arm straight down and slowly relax your grip until you are barely holding onto it. Now let it slide through your hand until you are holding the smooth part next to the tail cap. Notice that you need to grip it harder to avoid dropping it? MagLites don't have aggressive knurling so it's a pretty good test.
I have one light that I had made from the smooth end portion of a 6D MagLite tube. I'm seriously considering cutting shallow grooves into it to make it harder to slip out of my hand.
ateallthepies
Rickmansworth, U.K
That's the test I performed PCC. Maglites are much more slippy on the knurling doing it this way. I suppose if you are gripping a light tight the forces are different and the skin must deform into the grooves?
Steve.
LGT
Massachusetts
I think the knurling is there to improve the grip when the light is wet from rain or whatever else would cause a smooth light to become slippery.
arodaz
I wish all my lights had the knurling of my keychained thrunite ti,,,love the feel,, aggressive sharp knurling
yliu
Hungary
Hmmm... Doesn't knurling increase surface area?
Just like heatsinks etc. when you have some sort of pattern on a surface, there surface area will always be larger than that same surface without any pattern.
TEEJ
NJ
Yeah, knurling increases rather than decreases surface area.
You forgot about the surfaces IN the grooves, etc...and that your skin does mold a bit to fill the irregularities.
When the light is wet, the knurling provides a place for the water to go leaving the peaks drier, etc.
As far as how aggressive it should be...that depends on the size and heft of the light, and, your hands, the weather, etc.
Any texture to the light will improve grip...just like tread on a tire or cleats on soccer shoes, etc.
I like it a bit aggressive, but shy of what will tear up my pocket, etc.
:D
markr6
I gotta revive this old thread because after using my T25C2 (with cigar ring) then switching to my Malkoff MD2, I just about pushed it out of my fingers when clicking the rear switch. The knurling is SO smooth that I think if you gave it to a blind-folded person and had them run their fingers across the surface, they wouldn't be able to differentiate between smooth and knurled aluminum.
I know I'm not allowed to speak negatively of the all mighty malkoff lights, but work with me here.
jorn
Norway
If your hands or feet gets wet for a longer period, they will wrinkle. It's the bodys way to increase the grip, add surface area :) No other part of your body will wrinkle up like this, hands and feet are the only bodyparts that will need extra grip when wet. So if your light dont have knurling, your hands will have if they are wet for a while :)
bykfixer
Dust in the Wind
I think some manufacturers combine style and comfort along with their knurling.
Others are out to provide the maximum grip possible, while others are going for pure style.
And like bicycle tires on wet pavement, some tread patterns help aid in traction, some patterns don't and some actually make contact area less grippy.
chmsam
3rd Stone
Not satisfied with the grip on you light? Not an elegant or fancy fix but this one works - friction tape. Usually found in big box stores with the electrical tape. Adds grip tremendously. You can also use bicycle handlebar grip tape or foam grips.
The best part about these solutions is that they not only give you grip but also insulate from heat and cold.
