got my L1D just a few days ago and want to share my thoughts compared to the L1T (as I dont remember a similar tread)
Package: nice as usual, also poch and spare tail cap and o-rings included. Light is very nice, all treads and rings lubed, good machining, good treads, Led centered, ...
perfect (as usual)
comparison:
* slightly larger (5 mm) slightly thicker (1 mm), thus barely noticeable but fitting hand much better (and I have small hands)
* directly --> beam looking more on the green side (but the L1T might be a tad on the blue and I am just used to this). L1D alone --> perfect.
* beam --> usual ringy cree beam, whitewall hunters wont appreciate. Hardly to notice in use --> OK
* brightness --> hmmm? :Thinking: L1T is same brightness as L1D on high/turbo? What happened here?
Then I noticed that there was still the 14500 Li-Ion in the L1T. Swapped with a normal NI-Mh --> L1D-CE kicks butt.
* current draw L1D-CE: 0.16/0.85/1.25/1.26 A (low/med/high/turbo)
* special modes SOS and dazzle are quite nice.
Only drawback: 14500 Li-Ion does not fit and (more important) no low levels with it.
High/low on L1T works good with 14500.
best battery: Ni-Mh for L1D, 14500 for L1T
wish for the future:
same model but with current draws: 0.1/0.45/1/1.25 A (real low/med/high/turbo)
PS: would trade a bit of throw for a slightly less focused spot
perfect (as usual)
comparison:
