I recently purchased a Bluetooth speaker/torch/powerbank. I decided to pull it apart (as you do) and removed the led, battery and power switch. I did so because the led is white super bright and is approx the size of an Australian 10c piece. I had an old torch body lying around so decided to put the led, battery and switch into the old torch body exactly as it was when it was in the Bluetooth speaker. My problem now is that no matter what I try the negative solder joint on the actual led keeps heating up to the point where it simply melts the solder and separates completely from the led. Why does the negative joint get so hot, one would think that it would be the positive joint if any that would heat up but not in my case it definately is the negative joint. The battery is an 8000 mAh, 3.7v li-ion battery. Is there any way to stop this and why is it only happening now and not when it was still in the speaker.
