LF5XT ONLY 50%
dkoenig
Hello my name is dkoenig,
I'm new to the forum and write from Germany.
Have a LF5XT. Unfortunately, my LF5XT lights only by 50%.
how can I get back to 100%?
I believe that my LF5XT is a battery over discharg mode.
How do I get out of this mode?
Are you familiar with the various click operations of the LF5XT? If so, do a push and hold, basically just hold down the button. That, in any mode will give you 100% output. If not you might need to do a factory reset.
Unfortunately, my LF5XT light only by 50%
Have a LF5XT. Unfortunately, my LF5XT light only by 50%.
I believe that my LF5XT is a battery over discharge mode.
Now, what I have done ..
Click C + HP = 50%
- Full batteries, batteries, 1.2 V and 3.7 VLI-ion
- reset funktion
-what can I do more
dkoenig,
can you do a factory reset? yes or no?
after the factory reset, insert fresh battery, turn on your LF5XT in mode 1 which is 50% output and then do a PH (press and hold). that should give you 100% output.
welcome to CPF.
khoo
Re: Unfortunately, my LF5XT light only by 50%
Welcome to CPF, dkoenig.
You posted this several times, so the other versions have been deleted/merged/removed. Please continue in this merged thread, where you have already received some responses.
