Mag Charger Mod
Optik49
Boston
What is the process for the Mag Charger Mod? I thought it would be a good idea to have everything for this Mod, soup to nuts in one thread.
  • One new or used Mag Charger.
  • One Welch Allyn 1160 Bulb. Is it a bi-pin bulb or a potted bulb?
  • Change the bulb with the Welch Allyn bulb. Is there anything you need to do? Or is it just drop it in?
  • Where can you purchase the Welch Allyn bulb? Light-Edge is not going to be around much longer.
  • I think that's it you're done 500 lumens that can be focused.
  • Is there anyone that can post some before and after photos?
Bi-Pin
Drop In but a mica heat shield is suggested to avoid damage to the reflector.
Litho123 had bulbs and the mica heat shield available in the past. Check the group buy forums.
Bi-Pin
What's the "Mica heat shield" look like? Anyone have pics. The group buy is closed. I guess an easy mod if you can get the stuff.
I these specs but I keep reading 500 lumens this says 327 bulb lumens?
Specifications: Welch Allyn 1160 Bi-pin Bulb.
5.0 Volt BI-PIN Miniature Halogen Bulb
3.45 Amps
17.25 Watts
550 hour lamp life
327 bulb lumen output
bulb lumens overdriven @ 6V
[(6/5)^3,3)*327]=596,82B-L----> 387,94T-L
you can PM fivemega for some WA1160 bulbs
:wave:good luck with your mod!
-FILIPPO
I haven't done it so I can't tell you what the heat shield looks like. I would imagine that the reflector would be okay for short bursts but probably would suffer from a long burn.
I have some...
It's a clearish thin sheet of mica with two holes in it for the bulb pins. You need to trim it to size and a round shape with a pair of sharp scissors. Originally used for tubes in good old fashioned circuits ;). If you order the bulbs from litho123, he includes a couple with your order. His thread is closed until the end of this week.
Ok, we're getting there. Anyone have photos of the Mod or before and after beam shots.
I have some...
I figured it was something like that. My dad has had a Magcharger since 1993. I recently sent it in for warranty work on the switch. Ever since I got it back I've been thinking of doing this mod for him.
