I keep seeing mention of a KD lens and also a P7 mod. I have a mag 4D with a KCC terralux and it sucks, where could I find more info about these other two options?
Or, you could just get the Malkoff Triple Drop for that from Gene Malkoff and have over 700 lumens of light up the night power that simply drops right in. You can get AR coated lenses from lighthound.com to make it really efficient.
A 4D Mag is way too big
Try a cut down 1D Mag, 2D-3D Malkoff dropin, powered by a single LiIon rechargeable (KD D-Cell, AW C-cell with a sleeve or a AW 18650 with sleeve)
I wanted to try an asperical lense, in one picture I saw a while back it looked like a lazer coming out of the mag cutting threw the fog. Had better throw than a DBS.
Here is the KD aspherical kit with the Mag drop-in and aspherical lens. I do not know about the quality, but it is not overly expensive. I have been toying with the idea of picking up one of the aspherical lenses. But it is not what I consider practical for my uses, so it is not a priority for me.
For the money you pay, you cant beat it :twothumbs
Get the complete kit .... dropin, aspherical lens, reflector and normal flat lens.
That will give you the option of running with a aspherical lens or flat lens.
Note ... for best results, use the aspherical lens WITHOUT the reflector
