AlexGT
Thanks newbie!
keep up the good work!
AlexGT
AlexGT
Empath said:My thoughts on a heatsink in the form of a washer shape device obviously won't work; at least not with the focus mechanism as is.
mdocod said:on the bright side- since these modules are designed to operate in poorly heat sinked senarios- they may work as nice drop-ins for other alkaline powered cheap flashlights.
if the sockets in maglights were machined from metal rather than molded from plastic, then the heat would transfer much better.
like a KIU socket but with a PR base and a hollow section for the spring/cam mechanism to ride on. .. just a thought...
funny thing to me is it says on the packaging.. "patent pending" for the electonics circuit that controls the LED... Would be really funny if that one slips through the patent office... considering that thermal managment systems that can "tune down" the performance of electronic devices have been around for many years., dating back to power amplifiers, computer proccessors and many other systems.. not to mention- current regulation is nothing new..
NewBie said:I really cannot believe MagLite actually did this...
ViReN said:it would be interesting to MOD the Module itself for different housings surrounded by Copper & Heat Sink Paste... ... another alternative would be remove the Emitter and place it on some other good heat sink mounting... as i believe the casing design might not allow much of heat flow and is making space for the Electronics....
ABTOMAT said:<snip>
Unlike Viren, I don't think they have any conspiratorial motives. Using drop-ins in their existing lights means no changes to the production line, part supply, and even basic packaging and instructions. Faster onto retail shelves. I can understand this. HOWEVER, for a company with the resources of Mag-Lite to do so little with the first new flashlight in about 22 years (honest, look it up) seems shortsighted.
<snip>
NewBie said:I know everyone likes a beamshot layout.
I'm currently working on them, here is the first teaser:
martytoo said:Newbie,
Why do you have two beam shots for Mag 2D LED Bulb (to the right of the Inova beam) ??
And, isn't it true that even though the measured beam is 50% of maximum when hot, this is just about the limit of what we can discern in brightness difference when using a light. That is, we will notice that the light is a bit less bright once it heats up, but only a barely perceptible difference will be seen.
Has anyone been able to make beam shots of the Mags cold versus hot? I think that would be interesting. ??
