precisionworks
There are as many ways to set lathes tools to center height as there are machinists. I sometimes use the Circle Machine Company tool shown below, and it works well in those situations where it physically can be used.
There are lots of other times that there's no room for the Circle Machine gage ... so I built (another) simple center height gage. As shown below, only three parts are needed - two pieces of ground flat stock & one piece of round stock. The round stock is cut slightly long and a sharp live center point is used to mark center height.
The round stock is faced off so that the scratch mark is still intact. The parts are laid one on top of another & center height is checked. At this point, the flat surface should be too high, leaving room for final machining.
The round stock is center drilled, tap drilled, & countersunk:
With the spindle set to the lowest rpm, a Balax Thredfloer forming tap is held by the Jacobs Super Chuck in the tailstock. TapMagic is squirted into the hole & flooded over the tap, the spindle is started & the unlocked tailstock is pushed forward until the tap engages. I keep a foot firmly on the foot brake & step on the brake as soon as the tap rotates in the drill chuck. Balax tap shanks are quite smooth & hard as glass, and the Jacobs chuck allows the tap to turn no matter how tight the chuck is. If you use an Albrecht keyless in the tailstock, don't expect it to let the tap slip
Some people will stop power threading after the tap has engaged three or four full turns & finish with a tap handle ... probably the best approach.
The three parts are put together with a pair of flat head allen screws. The reference edges are brought to a sharp 90 degrees on the surface grinder.
The top surface is ground down until it is .010" higher than lathe center - this flat is used to set ID tooling (boring bars, etc.) The other end is ground down an additional .010" until it's at dead center (see the step at the front of this photo). The "step" is used to set OD tooling:
Using the tool is simple, bring the point of an insert next to the reference flat & use a small straightedge to sweep the top.
Finished gage in use.
