wquiles
Well, as it turns out, although I still consider it a great buy, the gage I got is "not" giving me proper center when the bubble is in the middle (target). The way I know? Do a facing operation. Only when the cutting edge is truly on center, you will get a flat face with no "nub". When I tried it using the target position, it ended up being a tad below center, and I of course ended up with a nub. I just adjusted the cutting bit until it got me a perfect facing operation, and then used this "true center" position to "calibrate" the center gauge. Now I know that I need the bubble in between "target" and the outermost line - so from now on re-centering tools will be easy and quick ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Piece of Al I used to do the test:
Even here where the bubble is a tad off-center, it still was a tad too low:
Will
Will
