I received my two Warriors today and here are my initial observations:
1) This light is not anodized, the finish is black powdercoat. (Personally I prefer powdercoat over type II; I don't think either is clearly superior in terms of durability if done properly.)
2) One of my lights has a clearly superior beam; nice, round and uniform in color. The other has a very reddish halo and rough edges around the main spot. It doesn't bother me a bit though.
3) What a crap job of packing they did. Both my lights had pieces bouncing around inside their respective boxes, scuffing the finish and damaging the screw threads on both light heads. I was able to repair the threads on my lathe, but CRIPES!!
4) The sealing o-rings are silicone; this is okay, but I think Surefire did a better job when spec'ing buna-n for their rings. Silicone is not good against tearing/abrasion (so keep them well-lubed with NYOGEL - silicone is not resistant to some types of grease). But, silicone has a much higher operating temp than buna-n, in the 400 F range... does it matter? Probably not, but these lights do run quite hot.
5) Mac was right, these are very bright lights, and they do run hot.
6) The vent holes do scare me a little, not so much from a cosmetics standpoint as a contaminant-intrustion standpoint.
7) To those of you who have spare batteries: Are any of you interested in a Delrin threaded plug to protect the contacts? If there's enough interest I would be willing to manage a group buy.
8) The clicky switch: I like its feel. It's a light click rather than a heavy click. It's not as tactile as the Surefires, but I rather light it.
9) If I think of anything else I'll edit this posting!
EDIT:
So I disassembled my light today to smooth out the focusing mechanism, and to see what makes this baby tick. (It's easier than you think.) First off, let me say this is a cleverly designed and very well-made light. I can't comment on the reliability of the electronics, but mechanically speaking, I am very comfortable with the prospects of this light's ruggedness. The weak link might be the lamp itself, which is suspended on wires instead of being solidly potted.
Disassembly of the light consists of removing the battery pack, focus lock ring and bezel. The reflector is threaded into the bezel and the two should come out together; if they don't, simply pull the reflector out of the head. Friction from its lower o-ring could be holding it in place.
The lamp assembly is threaded into the bottom of the head; it has notches for a spanner, but easily unscrewed by hand on both my lights. Both my lamp assemblies had all kinds of greasy fingerprints all over the electrical contacts so I was feeling real proud of myself after cleaning them hahaha.
I noticed that almost zero lube was used during the factory assembly of these lights, and a touch of Nyogel went a LOOOONG way toward making these things run smoother. Also, one of my o-rings was torn, probably due to being siezed and stretched when screwing the light together. I ended up replacing all the o-rings with buna-n, which is a lot more durable than silicone and doesn't tear as easily.
Now this is a purely subjective observation, but both lights seemed quite a bit brighter after this cleaning up and lubricating routine. Perhaps it's the placebo effect, but perhaps it's the cumulative effect of fully seating the lamp and cleaning its contacts?
By the way, I don't think dirt intrusion into the head's ventilation holes will be much of an issue. The reflector is o-ring seals on all sides, and can be easily removed for cleaning if necessary. (Avoiding contact with the mirrored surface, as usual.)
I also tried disassembling a rechargeable battery pack to see what the deal is with one of the on/off switches, which doesn't have a solid feel to it. But, I lack the proper spanner and don't want to risk scratching the electrical contact traces. (Other than that, the pack looks easily disassembled.)
