HKJ
When looking at ad's for flashlights, some of the specification are not always what they appears to be (or maybe exactly what they say). Some manufactures are very good at specifying their flashlights, other forget to mention some conditions (or hides them in small print), making the paper specifications look better than the flashlight is in real life usage.
Some examples I have see are these:
Maglite: 3 watt led: Yes they are using a 3 watt led (I suppose), but they are not running it at 3 watt.
200 lumens: Is the value out the front of the flashligt or is it from the bulb/led? (i.e. torch/bulb lumens)
200 lumens, 30 hours: But not at the same time!
xx watt: Specifying how many watt is put into the led, does not say how much light gets out and sometimes the specification does not event say what is put into the led, but is only used to position the flashlight output relative to the previous model.
xxxxxxxx candlepower: Scaling the output back to the reflector is not correct, the scaling only works for a point source.
runtime xx hours: What is the stopping conditions for runtime: 50%, 1 lumen or ? For some light the difference in runtime can be very huge between a 50% or a 1 lumen condition.
xx lumen: When is the lumen output measured: With fresh batteries or with nearly extinct batteries or somewhere in between? This is very important with incandescent flashlights and unregulated led flashlights, and less with well regulated led flashlights.
Most of these specifications are correct, but can be misleading when not stating the conditions!
Any other "misleading" specifications or comments to this?
