bombelman said:
Explain please ?
The 10 Crees are arranged as two parallel strings of five in series. A series connection means: (+) from the driver (battery, this is direct-drive) goes to the (+) on the first LED of the series, then from its (-) to the (+) of the second LED, from it's (-) to the (+) of the third LED, and so on...
Here's another way to explain it. Assume 17.5V from the battery and 3.5Vf for each LED. First one in the series string is running from 17.5V to 14.0V, second is running from 14.0V to 10.5V, third is running from 10.5V to 7.0V, fourth is running from 7.0V to 3.5V, and finally the fifth in the string is running from 3.5V to 0V. So you see, of the five positive pads and five negative pads underneath each of the five Crees in one series string, exactly one of those pads matches the voltage of the heat sink: the negative pad of the fifth in series. So if he did file off the pads, he would have to file both the postive and the negative on eight of the ten LED's. Two of them have to have just the positive filed off.
Gee, that's harder to explain than I thought it was going to be.
I still like my thick-epoxy theory.
