rice rocket
- Joined
- Dec 1, 2009
- Messages
- 53
Let me know if there's any glaring mistakes or things I've overlooked. This would be my first build. My goal is to build the shortest body Mag by moving the switch into the tailcap. Runtime will be ***, I know.
I'll be running this in a 4x1.2v NiMH AA configuration, direct driving a SST-90.
I'm not an engineer at all (mechanical nor electrical), but I know a little Solidworks and a little machining, so I figured since I have access to machine tools, I might as well be somewhat productive in my free time.
Parts:
2D Maglite from Home Depot
SSR-90 emitter from AVNet
1.375" delrin stock from McMaster-Carr
1.5" 6061 aluminum stock from McMaster-Carr
52mm glass lens from DX
50mm optic from DX
Switch (still need to acquire, any leads?)
Arctic Alumina thermal compound
Misc. wires and such
Here's the 3D model.
Battery holder will be made using solid delrin stock and milling out slots with a 5/8" ball end mill. Springs will be flat brass that I'll make a keyway for in the delrin holder.
So that's where it sits now, still modeling. Things I'm looking at:
Thanks, I'll update as things come together.
Parts:
50mm optic from DX
- Focal length of DX optic? Right now, I have about 38mm from the base of the heatsink to the glass (and you can see that I've countersunk the heatsink pretty significantly already). Subtract the height of the emitter (7mm) and I'm not sure I'll have enough, even w/ the Mag head unscrewed all the way. Also, the further I countersink the emitter, the more stray light I create. Datasheet says 80% of the light is available at around 35 deg off center, and if I countersink it further, I'll be losing focus OTF.
- Switch? Ideally, I'd need the lowest resistance switch, with capability to handle 9-10A. Any leads?
