need advice for automotive lights
I
ilya
Guest
what led's would you experts here recomend to use on a motorcycle 12v line...i am going ot be using theese for turn signals so...the brighter the better...also is linking 4 or so together a prob? thanks for this great forum
Ilya
darkzero
Flashaholic* ,
SoCal
Are you looking to custom make a light or making just a socket type replacement?
I made some for a car a while back here.
Eric_M
Motorcycle Turn Signal LED Conversion
I'm going to bring this old thread back for a bit. Could someone give me a resistor value to use with 4 led's wired in series for a 12v system. These will be for motorcycle turn signals.
Thanks,
Eric
Added:
Found my answer:
http://www.candlepowerforums.com/ubbthreads/showflat.php?Cat=&Board=UBB14&Number=871113
Based on this info I'm going with 4 led's in series with a 100 ohm, 1/8w resistor.
The led's are:
5mm
25mA forward current
2.4v max
Using the resistance calculator in the thread I came up with the above value.
Eric
