stienke
Hi everybody , I have sold a Olight M20 Warrior R2 and I had no problems with this light but the new owner have problems.
I can't help him , I need the expertise from this forum , I put here the questions he ask me,
I'm experimentig some problems whith your flashlight, and I really hope you can help me.
As I used with the 18650 (Ultrafire 18650 3000 mAh), I noticed the damned "low voltage signal", and, if I try to change level until a few seconds are passed since It blinked, I experienced problems in changing level. But if I wait 'til it flashes, it works fine. The real problems, comes out when I use rcr batterys: the rcr tube is really tight, and it's really hard to insert or extract the batterys. But when I use the 2 RCR123, I can't use the flashlight.
Just let me explain better: I enter the tube with the 2 rcr in the m20 with the head tighten, and if I try to switch on the flashlight I get no answer. The tailcap seems to work, but the led doesn't turn on. If I I loose the head a little, it works on low level. If I tight the head again, the m20 turns off. So, if
I try to change level, I simply turn on and off the flashlight.
At the beginning I though this was due to a circuit's bad contact, so I cleaned with alcool the battery and the circuit. I got the same problem. I changed RCR battery (I took another couple of Ultrafire RCR 3,7 V 800mAh), or use Primart Cr123. The same problem, even removing the CR tube and using directly the batterys.
