Need help on bike light reflect
Krit
Thailand
I make bike light with SSC and standard flashlight reflect. The light is very strong and vertical side spill. I try to find new reflect or lens for make the beam shape narrow in vertical direction.
The general reflector make a good spill for flashlight but not very good for biking. Light always spot throw directly to the car driver's eye.
Please suggest for the new one.
I just found here http://www.ledsupply.com/l2-op-520.php
while these will make the light widened into one line, the useable output gets dimmer.
Better use 2 or 3 Leds, tight focusing and set them a few degrees offset from the middle axis.
much better light and nice beam.
example here:
dynamo powered tri-cree
unf. in german, but if any questions come up, just ask, for the most parts the pics speak for themselves
http://www.mtb-news.de/forum/showthread.php?t=268099&highlight=tricree+n+da+house
Hi Krit
Are you using the 20mm SSC reflector?
If so - the Khatod 20mm SSC optic is a better option for less sidespill -more out front.
Reflector
Optic
You can get them from
PhotonFanatic
Cheers
Dom
Thanks for all suggestion.
Now I use Calo Optic (not sure exactely name) for make smooth beam from SSC P4 at 500 mA for long run time.
I will try 20 and 25 mm optic from PhotonFanatic. I see 20 mm oval beam shape in pfd file but I don't konw he has it or not.
