I think that pic is too big for forum rules.
It looks like your jumpers are all connected, maybe something is fried?
No that would be direct drive.I'm wondering if it's possible to connect the LED- and the Bat- at the same spot from the driver as shown in pic?
Is this driver, LED, and Bat all in parallel?
Norm
Reneki, your first post image is using the "PNG" format (instead of JPG). As a result, that one photo is 2.7 MB's that people have to slowly download. It would be great if you fixed that first image file type.
Thanks
Are you using a single 18650 with it? What's its voltage under load? What's the Vf of the LED?I tried out this 8x7135 board i got with my P7 and 18650, but I'm getting 800 ma with it, ...
The way these boards work is that you connect the AMC chips all in parallel so that the drive current for each chip is additive.
Do you have a multimeter to check continuity? I assume so since you've measured current draw. You can check that all of the Vdd legs are electrically connected and that all of the OUT legs are electrically connected. Check that each of the 8 AMC chips have their GND pin (or the big tab at the top of the IC) connected to ground (the outer, gold trace on the board).
To hook up the two boards, you wire them in parallel as well. Thus, LED+ from board 1 goes to LED+ on board 2.Thus, there should be some sort of conductor that connects the center solder point of the two boards. Similarly, there should be a conductor connecting LED- (the solder pad near the OUT pin for Q2) for board 1 to LED- for board 2. Finally, ground for board 1 connects to ground for board 2. Since LED+ shares the same solder location as Vin, the Vin parallel connection is already made.
In your first photo, there is a hole drilled through the board near Q2, which should allow a wire to connect LED- on board 1 with LED- on board 2. I don't see the wire, though. I just see the hole. Check if the wire is there. You need it for the parallel connection of the two boards.
How are you measuring your current draw?
For completeness, I suppose you could also test the diodes.
For the P7, what is the voltage bin, or even better the actual Vf when you've DD'ed it at 2.9A-3.0A? What brand of 18650s do you have?
I've read heat drops the Vf, and I've read heat makes an LED less efficient. But that Vf should make it pretty easy to use the board.I've read a lower VF makes it more efficient, ...
