Nine-Eight
- Joined
- Apr 13, 2009
- Messages
- 3
Hi! I have a flashlight I'm toying with, Had a few questions for you educated folk out there...
I'm looking for a LED thats above 500 lumens, that I can run with 6-9v, with a good color choice for use at night...
I used to be familliar with the cree options but it seems they've changed some model numbers around? I just spent some time on their website and I feel lost..
also, i've noticed there is a much larger amount of optic choices now! what kind of optic would I want if my goal is to have a useable long-throw spotlight AND a healthy amount of flood? is there some combination of optic and type of reflector I can use?
if this is too much to answer, can someone point me in the right direction to start learning about these things so I can make an educated decision?
if any background helps: I figure since I'm looking for 500 lumen and up I can get a pretty useable amount of light in both flood and spot. I plan on using a pulse width modulator circuit so that I can conserve battery life and dim the light when the brightness isn't needed. i'm shooting for something useable for exploring in the night hours... so a setup that throws out, say, 40-60% of the light in a long throw spotlight and the other 40-60% as a wide angle flood would be awesome! I'll be planning on using a buck/boost driver so that I can feed it anywhere between 6-9 volts depending on the battery setup.
I know this is a lot to ask about! thanks guys!
