First a disclosure: I am currently infatuated/enamored with Neutral White tinted LEDs - because I feel they give just the right compromise for a flashlight - which for me the main purpose is for seeing well in the dark.
That over with I wish to acknowledge 4Sevens' generosity for these Quarks that I have to look at.
Size -
not much to see here - there is almost no visual external difference between the Neutral White version and the regular cool white Quark AA. I have the marvelous finger loop on the Neutral white and the clip still attached to the cool white - so that I can recognize them more easily without having to turn them on....
Heads -
again hard to see much visual difference - but as discussed elsewhere the Neutral white seem to show more brown in the reflector.
Head to head - well OK this Neutral White head is actually the one that was on the Quark AA2 which I reviewed in
Neutral White (Warm Tinted) - Quark AA2 Neutral White Comparison Review
all I did was to put the head on a single AA body - and voila! I have a Quark AA Neutral White......
similarly I could have put it on a single CR123 body and end up with a Quark 123 NW - such is the versatility of the Quark range - which follows the "Lego" trend set by Fenix in their L/PxD and L/PDx series.
vs. 4Sevens Quark AA Cool White both Max NiMH
visually and in the beamshots these seem about the same brightness -
but the different tints makes the comparison difficult -
So I removed the colors by desaturation -
the levels are still "similar" with perhaps the cool white being brighter - which it should since it is an R2 as opposed to the Neutral white which is a Q3......
vs. NiteCore EZ AA-W (Warm tint) (NiteCore uses mostly Q3 5B) Max NiMH
the EZaaW seems brighter - it is spec'd brighter - the small overall beam also concentrates the light more - so it seems brighter still.
Lower levels -
vs. 4Sevens Quark AA Cool White both Min (Level 1 Moon mode) NiMH
vs. 4Sevens Quark AA Cool White both Low (Level 2) NiMH -
vs. NiteCore EZ AA-W (Warm tint) Low (Quark level chosen to "match" EZaaW) NiMH -
here's a good case in point - the NiteCore is rated about 10 lumens on Low - whereas the Quark AA is supposed to be about 18 lumens on its level 3 "Medium" - so why do these look so close?
Is the EZaaW over-achieiving (not so desirable on a low level) or the Quark not keep up with specs? - can't say for certain - BUT it is more likely merely because the Quark's beam is so much wider - so it spreads its light out more than the EZaaW - hence why these kind of look the same level - the Quark probably has about twice the area, accounting for the apparent similar visual brightness......
INDEX to follow up parts -
Comparison with 2x CR123A version the Quark 123-2 to check the circuit regulation, by seeing if lower levels are similar - Post #3
Standardized stairway beamshot - Post #4
Standardized stairway beamshot using 3.7V rechargeable Li-Ion 14500 - Post #7
Size -
Heads -
Lower levels -
