hi flying turtle,
compare to the high brightness of my fenix LOP SE, the LF2 has a much brighter spill. also the beam diameter of the LF2 is smaller compare to LOP SE. LF2 beam diameter is about 1 metre at 1 metre distance.
my LOP SE does have a slightly more intense hotspot than LF2's.
mikiehead,
i think the smaller beam diameter of the LF2 best fits your requirement as the LF2 spill beam does not intrude into the personal space of the person sitting next to you in a restaurant/opera house/concert hall/conference room.
gunga,
actually the LF2 can also be considered as a 3 stage output light. program the standard mode 2 output levels to YOUR low requirement and 100%.
when you need something in between, switch to user adjustable mode by twisting twice (SW x 2). the LF2 enters user adjustable mode at 50% brightness. if you do not do any adjustment, the LF2 stays at 50%.
to switch back to standard mode, twist once (SW x 1) and you are back to YOUR low and 100%. easy and simple.
krahl,
glad you got your LF2 so quick! please do post more about how you use / feel about your LF2.
thanks
khoo
