Re: Inova X1 And Rechargables
cd-card-biz wrote:
"Holding an alkaline Duracell and Tenergy NiMh side-by-side, the negative (-) end seems the same on both. It looks quite well exposed enough to contact the switch plate.
I even tried a small piece of aluminum foil placed on the negative pole to raise it up a bit. No joy.
It would be interesting to know if those having sucess using NiMh cells have the "old" version of the X1."
I have an older style lensed
Inova X1 Spot - White (linked review) and both my NiMH AA betteries worked in it (Ray-o-Vac 1600mAh and jWIN 1800mAh)
When you checked your batteries were the rechargeable and primary exactly the same length?
ie: when inserted in the X1 - does the rechargeable battery still protude a bit from the body tube?
Just a small possibility this Spot X1 is a relatively recent one - I was told bought from Target circa Sept/2005 - and might be using the Nichia CS....
HonorKnight wrote:
"I've burned out two of the new style X1's now using rechargeable batteries. Both times in less than a week. I contacted Inova and they responded to say that rechargeables are not recommended and the use of a rechargable voids the warranty. The only recommended battery is the AA alkaline."
That's very interesting - thank you so much for that input.
Rando wrote:
"According to this, the 3.6 volt lithiums are incompatible with all Inovas. Don't see any reason to think that NiMH would be any different."
I can understand that 3.6V Li-Ion rechargeable burning out the X1 -
this is
WAY above a single alkaline AA rated nominally at 1.5V -
but NiMH rechargeables are nominally rated at about 1.2V - below that of alkalines.
