rizky_p
I am building M@g Hotwire mod using Mag 4D, i am planing to use 12v 35w 2000 hours/~2950K rated halogen bi-pin bulb. What is the best battery to use for this setup? i have one in mind using 12 Sanyo 2700, will it hold the voltage at such load to everdrive the bulb?
I know i should have used CPB or at least enloop but i have plenty new sanyo 2700 around and use it instead to keep the cost to minimum.
How about AW's 17500 lithium 4S2P configuration? is it good alternative?
What is the pros and cons between 6v and 12v halogen bulb? should i use 6v bulb instead since it will require less cells therefore cheaper? But all 6V bi-pin i found have vertial filament which looks realy weird on my reflector.
I cant get any exotic lamps such as WAs so i have to stick with common halogen bi-pin.
FYI.
I am using unbored 4D body
Kiu High temp socket kit.
no resistance fix applied to any parts of the mag.
no battery adapter, i will solder all the batteries and make it into pack.
Many thanks.
Rizki P.
FYI.
Many thanks.
Rizki P.
