Ooh, I like! :twothumbs
Looks gorgeous! Where did you get the Cree UV LEDs?
Cree has UV leds? wow....i need a P60 version of that...
Crenshaw
Great work CM
Hmm.. i need to get me one of those emitters too.
Let me know if you make a order Will.
:wave:
Benny
Um, did you know that the Shoppe has UV Crees mounted on boards? 27 in stock as of right now. I've had my eye on them for a long time. http://theledguy.chainreactionweb.com/product_info.php?cPath=48_52_79&products_id=673
I'm assuming these are the ones that are used in the UV A19s. If they are the description states that they are 7090, wavelength 390-410nm, flux 200mw @ 350ma.
But please don't buy them all up. I need one too.
...BTW, thanks to chimo I was able to increase the current on this board. I thought stock current was 500ma but it's not even that. I'll post details in my other thread.
It's the 0.15 ohm resistor that sets the current I already figured that out.
Yes that was a given. I'm not electronics expert so I had to ask to figure out how to calculate what I wanted to drive it at. I don't like to just throw a resistor on there & experiment.
Chimo told me what to measure & the formula to use. According to what he told me I calculated stock current max to be .313333. That's pretty spot on cause I measured .314ma at the emitter.
What did you set yours too? I originally wanted to go higher than 500ma but I don't think it's a good idea due to lack of heatsinking.
Good point. A .10 resistor should give you just under 450ma. I bumped mine up to just over 500ma. Before I rarely ever used anythin other than high. Now & with a R2 with better tint I find myself using the lower levels more.
Waaa? You sold the light already? Knowing Benny it was probably him. :wave:
I regret modding other lights with the two R2's I've got. I need to get some R2's with a warmer tint and pick up another EX10 to mod. But my busted thumb is getting painful with the last few mods I've done so I need to take a break for the rest of the day
