Yes, this is indeed normal.
By the way: did you use that MN11 with primaries or with 2X 17500s?
In the last case.... it is no surprise it exploded. You are overdriving this lamp assembly severely when used with 2X Li-ion batteries.
The MN10 will withstand them.
Let me try to explain this:
primary CR123A's have a no-load voltage of 3V.
Under the load of an MN10, they sag to about 2.5V each
Under the load of an MN11, they sag to 2.1 to 2.2V each.
This means, an MN10 is powered by a total voltage of about 7.5V when using primary CR123A's whereas 2X Li-ion will have 7.4V so that's no problem.
However, the MN11 will only see 6.3 to 6.6V in total when powered by 3X CR123A, which is way less than two Li-ion batteries will provide!! So, the MN11 will be overpowered quite severely in this case!
Exactly the same goes for the P90 and P91: the P90 will withstand two Li-ion cells, the P91 will have a very limited life on them....
Timmo.
