LA OZ
Ok, I thought we should start a thread to said some good thing about the Novatac light. After all, it is one of the best out there.
1. Beautiful smooth white flood beam from the orange peel reflect + Seoul combination. It reminded me of the Amelite T5.
2. Just wonderful interface and programming for the P series. I just love it. I have heard so much about HDS and this is the first time I handle something similar. This is what I called an intelligent torch .
3. You can reset the torch to recognised the battery type and therefore you don't need protected cell if you used according to instruction. I ran my inferior freshly charged ultrafire 16340 and it lasted about 20min full bright and this dropped down to half bright for another 40min before it gave an intermittent blinking signal for battery change. I took it out and the voltage read 3.6V. The torch was only slightly warm to the touch for the 85P.
4. I like the fact that the bezel can be removed and easy access to the reflector and LED.
5. The switch button is nothing like it. It is great and tactile. I hope it last as there is a lot of clickings when playing around with it.
6. Nice size - same height as the P2D CE but slightly wider.
I have recently tested it on the LC16340 RCR123 and it lasted 55min Max .
