ok well this isnt tested but common sense tells me that if you take the reflector and dremel/put on grinder and reduce the angle of the cut (the end that you cant see when its assembled) it will allow you to focus more accurately(requires more rotation for same adjustment). at the same time, it will give you less range of focus.
dont know if anyone knows/cares but i thought ide post it.
should wourk just opposite if you increase the angle but seeings how the cut m*g has made already allows for full focus( and unfoucs???) i dont know if there is any point.
not really sure if there is any point anyways but if you want a cheap mod just to say its different do this. haha :twothumbs
