A Ace12 Enlightened Joined Mar 13, 2007 Messages 321 May 12, 2008 #1 Will a P7 fit in place of a Lux III?
B Bronco Enlightened Joined Dec 3, 2003 Messages 509 Location Los Angeles May 12, 2008 #2 Others can answer your question with more specificity than I'm able, but the short answer is that the P7 is larger than the Lux III. Size wise, it has much more in common with the Lux V emitter. Ergo, a direct swap out is not likely.
Gunner12 Flashaholic Joined Dec 18, 2006 Messages 10,063 Location Bay Area, CA May 12, 2008 #3 Depends on the light. If you are just thinking of a swap, the Seoul P4 would work better.
