P91 question
Waspy
Wiltshire
I have a Surefire 9P currently using 2xAW 17500 rechargeable 3.7v batteries.
Would it be possible to use a Surefire P91 lamp with these batteries or would I need CR123s?
Thanks in advance.
You should be fine using the two 17500 batteries; their combined voltage when fresh will only be 8.4 volts, versus the 9 volts of fresh CR123s.
OK thanks.
How about one of these? OK for a 9P? batteries as above?
ThruNite P60 Style Cree XP-G R5 LED Drop In Flashlight Upgrade Engine - SINGLE STAGE
300 Lumens (1A Drive Current)
2.7-9V input voltage
Cree XP-G R5 LED
Outer spring is removable for some fitments
Aluminium textured/OP reflector with bronze heatsink base
Bezel diameter: 26.5mm
Copper base diameter: 19mm
Height including support spring: 36.7mm
Height excluding support spring: 28.8mm
Any p60 / d26 drop-in will do. you could do that one you posted but there's lots more options, specifically, you could get something with a tint you liked which may give your drop-in a lot more usefulness to you.
(for example, the cree 5B bin is great for me, such as the xpg R4 5B)
re: p91 - if you went to 2x AW IMR cells you'd be in the clear. Or use a lamp assembly with a longer run-time/less output to reduce the strain on the cells, then you could use your AW lico cells in spec.
