Back to your polishing, I would say a good tube of polishing compound and soft cloth accompanied with good 'ol elbow grease (literally, heat and friction will burn out the scratches with/from enough pressure) will polish it after some good work. With a deep enough scratch, it may be necessary to use some different kinds of sandpaper, working up in grit numbers to a very fine smoothness and then do the mirror (or whatever finish you prefer) polishing with your compound. I have successfully polished titanium in this way, but I did have a lathe turning it at very high RPMs to make it that much easier. I can't say that its the easiest metal to polish, especially by hand, but it is very doable. :thumbsup:
