Re: Powering an LED light with a potatoe?
They used to power a flashlight bulb by sticking copper and zinc electrodes in a raw potatoe. Worked even better with a lemon... the only thing that's different for an LED is you need a minimum voltage for the gate to work, so why not ?
You'll get some electricity going by sticking a copper and a zinc electrode in anything that's even somewhat acidic, if you keep them close enough. That's how batteries used to be made. The stronger the acid and the larger the electrodes, the more "juice" you get out of it.... because, quite simply, as you use up the stored energy, the acid is neutralised and becomes more neutral, so you get less and less power. And fruits and veggies ripen up with time and become less acidic too.
