Doing so runs the risk of the bulb exploding inside the headlight, destroying it. Running the lows together with the highs can only be done safely if the lows are produced by different bulbs than the highs.
Thanks! I already thought it would probably not work, so I didn't make it so that they can come on together, and I'll leave it as it is.
The Xtravision sealed beams are junk.
Well, they make the best light I have had on a car yet --- part of which is due to them being pretty high above the road. And they are cheap.
Poor optics and sloppy focus.
The focus is sloppy, yes. They shine a lot of light to the sides, and the beam pattern on the front could be better. They are probably losing a lot of light by that which could be used much better.
Get GE Night Hawk H6054NH instead, it's much better focused and uses axial filaments instead of transverse for better optical efficiency. Amazon.com seems to have them on permanent sale for $20 apiece. Or get some good H4s (shop carefully, there are more bad ones than good ones out there).
Hm ... Perhaps the best option is to get the replacements Hella makes (about $45 each), allowing you to use a H4 bulb instead. I was told they are pretty good --- but I'm doubtful about H4 bulbs and about Hella. It seems to me that Hella used to have great quality years ago (20?), and that's where their reputation comes from. They still have good quality lights, but the price for those is just ridiculous. I've had a few of their lights and was disappointed both with the quality and the performance.
As to H4 bulbs, I've never seen a headlight with those that made really good light. Best I've seen was on a '93 Mercedes 300D: The beam pattern was really nice, but because the light was spread rather wide, it was overall too dim.
And I've had bad experience with the bulbs that are more blueish or otherwise are supposed to provide more output. Some of them last only about a month; the best was 1/2 year. I don't buy those anymore.
The rewire with heavy-gauge wire and relays is a good idea, many cars have a lot of voltage drop in the factory headlight circuit.
Yeah, the manufacturers are trying to save on the wiring too much. I measured the voltage on the stock wires while I rewired them: only 11V without the bulb connected, and my cheap voltmeter shows about 15.8V when it's actually 14.4V. So with the stock wiring, they might get only 8--9V.
Hm. Are those Hella replacements really good and better than those Nighthawks? I think I'd rather spend the money on the Hella replacements than another $40 on 6054s.
