65535
I've been struggling with making proper square nuts to run in uni-strut to make an adjustable motor mount that I could mount to my lathes G-11 base.
I need 8 .3125" thick ~1.25" x 1.75" pieces cut out of mild steel.
In the center of the pieces there needs to be a hole for threading either an I bit or a 9/32 bit would suffice. I can tap myself.
4 of them will need a roughly .125" x .375" (depth x width) groove milled in the bottom along the 1.75" length through the center to accommodate passing over a button head screw in the bottom of the strut.
Please PM quotes including shipping and turn around time. Thank you.
