RoGuE_StreaK
I've recently bought a '12 Mitsubishi Outlander; the previous model with the Lancer face (eg. pic here). I'm trying to figure out the "best" daytime driving lighting method, preferably using the stock setup. In Australia DRLs are not mandatory, and this Outlander doesn't have the DRL setup installed (extra bulb in the "fog" light).
Notice I use "fog" in inverted commas; I actually have no idea what I should be calling these, and what the legal usage of them is here in Aus, as they are fitted with white lights, H11 I believe. As the car has bi-xenon projectors I figure from reading here that they are no longer the best for being noticed in daylight (I used to drive with my low beams on in previous cars, on long trips etc), the parkers are pretty woeful little dots of white, but I don't know if driving with the parkers and the "fogs"/"driving lights"(?) is legal in Aus. I know for sure the yellow foglights aren't legal to use unless in "adverse conditions", but I don't know if these ones classify more as DRLs? I used them driving through a shadowy rainforest the other week, but am a little concerned as to whether they should actually be treated as fog lights and not used in the presence of others, which cuts down my options for daytime visibility?
So, as a compromise and spurred by the "high beam as DRL" thread, I'm wondering if I can/should run a lower power level to the H11 bulbs as a DRL when desired? Ideally I'd have a multi-stage LED setup but that seems to be a no-no.
