Gryloc
McGizmo,
Can you share some information about the different reflectors that you have or will have that will work for the Lumileds Rebel emitter? I have been thinking about a few of the posts you made about that new, prototype reflector for the Rebel in some other threads, and I wanted to see how and when we can attain such a reflector. Two reflectors I have in mind is this 10mm reflector that you are working on, and then your older McR8 reflector. You have some more stock of the McR8 reflector at the Sandwich Shoppe.
How well does the McR8 work? Do we have to remove any material from the back for it to sit lower on the Rebel and focus? I heard it worked with some Nichia emitters, so I figured the Rebel may also work, possibly.
Now you said that since the die of the Rebel is so low (right above the ceramic substrate package), you almost have to put the Rebel emitter on a pedestal and almost put the entire emitter package into the hole for it to focus with any other reflector (IMS series and the existing McR line). Is the beam desirable with the Rebel and these larger reflectors, even when focused? You mentioned that small reflectors with proportionally large dies will give a larger, but even hotspot. Maybe you can elaborate more on this for everyone else. It is very interesting information! Maybe you can make the comparison with the Lux V in a 20mm reflector.
I wanted to mod a small light with one of these reflectors, using the Rebel, and I wanted to make sure everything will work okay, even if I have to do some modification to the light and/or reflector. Thank you!
-Tony
-Tony
