ggroyal1117
- Joined
- Mar 16, 2011
- Messages
- 19
I use Dr. Marty's conductive grease to lubricate the slides.
http://www.bigsquidrc.com/dr-martys-easy-on-conductive-grease-review/
I realize that this thread is a bit old, but I was trying to research the right current to use for charging my lithiums in my new XTAR VP2 and this thread touches on it. I assume I should be using 0.25A for 18350 and RCR123. The owner's manual states that you should use 0.25A up to 18700 but it takes forever to charge my 18650 at 0.25A.
I'm most concerned with safety. Is there any risk to charging at 0.25A? As I understand it, it can be risky to undercharge a cell because the charger doesn't recognize when it's fully charged.
My next concern is long term battery life. If I charge at 0.50A or 1A, am I shortening the life expectancy?
Of course, I'd love to charge the batteries faster, but not if safety or battery life would be compromised.
And on the topic of charging faster, I'd love a 4-cell charger that is just as good. In reading the reviews, I'm not sure that anything else out there compares to the XTAR. Will the XP4 be the next best thing if I wanted to charge 4 simultaneously?
Thanks to both of you for your quick replies. So it looks like I can safely go up to an amp, even up to 1.7 amps if the charger allows for it. Very different from the chart in the Xtar manual. So HKJ, do you have a favorite 4-bay unit? I don't really care if it also does NiMH, as I already have a Maha. I'm looking for a way to quickly (and safely) charge my 18650s, 18350s, and CR123s. Considering the Xtar XP4 and the Jetbeam i4 pro, but I'm open to others. Thanks for all of your help on this.
I see you didn't mention the i4. Is it not in the same league as the others you mentioned?
The reason I mentioned 1.7 amps is because I read that 0.5c is acceptable and I have some 3400's.
So there's obviously not a general rule that will allow you to calculate the ideal charge current based on the capacity.
No. Once it was 1C and that is still a good guess for smaller cells. For 18650 the safe value is 1A.
Reading some data sheets may increase the charge current significantly for many cells, some high current cells can be charged at 2C (Price is reduced lifetime).
Hi ViperxpI will have the latest XP4 version hopefully within a week. I can post a review of the charger. It will not be as half as technical and profound as HKJ's one, but it will answer some interesting questions. Are you guys interested?
I received the charger today and noticed Sanyo XX was getting too warm at 1A. It had 57°C (134F) when I decided to terminate the charge. I'll see how NiMH batteries do in the following days.
You will often get a fairly hot battery just before the charger terminates, due to the way -dv/dt works.
The problem is that the positive terminals, as kreisl mentioned, transfer insane amount of heat to the batteries. The terminals are still very hot minutes after removing the cells...
Intellicharger i4 still remains the safer charger out of the two. But I just can't tolerate slow charging speed so I can put XP4 to better use.
