Linger
I am creating this thread to collect your recommendations, any comparison photos / comments regarding three incan formats: a 2D M@glight RoP (in this case with KD reflector), D26 drop-in (FM Sunlight), D36 (Lumens Factory Turbo head). Do you recommend standardizing to D26 format for lego body pieces complementary with an led collection, for ease of portability and reliability (multiple d26 hosts and redundant components). Or branch out with a 2D RoP. Or trying to meet half-way and getting a D36 Turbohead.
I'm asking for general impressions of these format. There are many G4 bulbs, different combinations, etc.
I presume the main advantage of the M@ghead is that the larger reflector producing a tighter beam. Is it true that this formate will out-throw most edc type led's (d26 xpe R2 drop-ins, Quark R4, Jetbeam IIIProST). Disadvantage is that it's a big light and it's a one-off deal, it doens't fit in with the D26 lego st. The RoP should be the most versitile for power (1-8AA, 1-2D, 1-4 half D, 1F, other li-co / imr combo's?) and thus bulb options?
The d26 (sunlight) head has a smaller reflector so presumable more floody. How short is the throw from this reflector? Does it compair favourably for close range lighting or is it outclassed by a M@g reflector at all distances?
The body components are all lego which is a plus. Batteries are limited to lithium combinations, so fixed between choices of cr123's, 16340's, 17670's, 18650's, with tube extenders.
D36 increases the reflector size but in the shootout it didn't seem like it made much difference over D26 heads. The D36 will probably make a great addapter for an sst-90 head, but what big plusses does it give for incan's?
Thank-you,
Linger
Thank-you,
Linger
