Others are noticing the same dilemma.
It's an emitter situation.
Basically, the "Hi CRI" interest began after the larger emitters appeared. The smaller emitters such as the XRE were already fading out of use at that time, and the larger emitters such as the XPG and even the XML were into the mainstream. So, the Hi CRI treatments got applied to those, and their contemporaries.
The only problem is that these newer emitters are too big to throw well in a P60 size reflector.
The M61 isn't much of a thrower, and neither is anything else that's modern in a P60. I noticed this immediately several years ago when the XPG appeared, and all the lights lost their throw. We had great throwing P60 size lights that all of a sudden had wimpy throw, because they were changed from XRE emitters over to XPG emitters.
Nobody went back to apply the Hi CRI treatments to the older emitters with good throw like the XRE. Probably because it kills alot of the output power, and they were older lower efficiency emitters.
Sure, people can get good throw from an XPG, but not in a P60 size package. They need to make a larger head size to do it.
And the XML is even worse, but it makes it up with brute power and high battery drain.
This is the dilemma.
Probably the best hope at present would be to hope for a Hi CRI XPG-2 with 400 lumens, and just hope that the extra brute power will give you the throw you want. The XPG-2 is already out, and maybe they'll offer a Hi CRI version soon.
For me personally, I have not attempted to get into the Hi CRI fad, because it was too limiting. The emitters lost much of their output with the Hi CRI treatment, and I didn't think that the Hi CRI makes much real difference to me anyway. I can tell what the colors are with a regular emitter. And I use a M60 for throw in my Elzetta, and it throws an honest 135 meters. And the tint is pretty natural looking too. I use the emitter that can throw in that package size, and forget about the "need" for Hi CRI. I lived for my whole life without Hi CRI, and I don't need it now. What I need is a light that is sized like I want, to throw like I want. And that means it needs an XRE.
