SF 9P vs. G3 vs G2L
RoRo9
Hey guys
im currently looking at buying a flashlight and have narrowed it down to the SF 9P, SF G3 and the G2L.
i shall be using it for general use with the occasional camping trip and other similar stuff. all these torches i am able to source from a local store in melbourne, australia at around the A$100 mark, which is the amount im happy to spend.
i like the brightness of the 9P and the G3 but dont like the limited runtime, though i was thinking of adding the Malkoff M60 led into it, and i understand that this should give me about 200 lumens output with bout 2.5 hour runtime.
the G2L was recommended to me as a good do it all light. decent output at 80 lumens and a good tactical runtime of bout 3 hours.
just wanted ideas and info about these things. im new on the scene and i apologize if ive said something stupid. thanks for the help :thumbsup:
Malkoff M60 (if you can still source one) will probably give you the best performance vs time. New M61 is suppose to be even brighter with even longer runtime but these are still hard to get right now. Also when first fascination with led light goes by many find the Warm version of M60 great.
Comparing to above the stock P90 lamp will be dissapointing. Some Lumens Factory bulbs will be better, brighter than P90, but still the runtime and lack of regulation (the light is dimmer after 10-15 minutes already) is a drawback.
With stock Surefire body you can use 17500 Li-on cells only (accept the cr123). To get about 2 hours of runtime with Malkoff M60 you would have to go for bored body to accept 18500 cells.
I would strongly recommend sourcing the flashlight from Electronguru here on CPF.
You can buy bored 9P or C3 directly from him together with 18500 batteries, better switch if you want a clicky and even the charger in one package. try to get the Malkoff M60, M60W or M61 and you have a nice light for many years to come without spending the fortune on batteries.
If you are going to upgrade with a Malkoff by all means make sure to buy a metal-bodied light, the 6P and 9P being obvious options. It needs to be metal to properly heatsink and draw heat away from the LED to prevent the LED from being damaged. The Malkoff is an incredible choice. I think you should wait for the M61 which is currently out of stock but even better than the M60, unless you want the best possible throw, in which case the M60 is better.
As carrot said, the 6P/9P is a nice platform for many of the mods we have here on CPF. The 9P is a good all arounder, it is easy to swap between rechargeables and primaries, it can be incandescent or LED, and there are lots of aftermarket mods available for it. If you can find it locally for a price you are happy with, then I think this would be a very good choice for you. :thumbsup:
The 9P w/ malkoff would be your best bet, as I assume it doesn't get to cold in Australia to need the nitrolon body...
Hey RoRo9,
welcome to CPF! Looking for one little flashlight can easily grow into a monster here, so watch out, hide your wallet & cancel you credit cards now before it is too late!
As mentioned above, 3 CR123 battery lights are a lot of fun, since 2 rechargeables (17500 size) can drive the same bulbs.
Starting out with a bored out body (18mm) allows you to use standard batteries as well as bigger rechargeables (2x18500), for even more power and runtime.
However, for ACTUAL camping I would:
A. not want to blind myself/destroy my nightvision/annoy fellow campers with my superbright flashlight
B. want something with awesome runtime and a good flood with an even tint
C. want something that uses batteries you can actually buy at a local store
This then brings us to this particular little beauty, the H501W Zebralite, the warm tint of this model makes it a joy to use outside, it will not blind anyone and can run down it's little single AA battery over 80+ hours....
This is a 3-stage light, can be used as a headlight, armbandlight, or you can clip it onto your clothes.
If I was going camping I'd just get two of those, and that would be perfect....
If you DO want a thrower as well, without spending too much money, for camping I would still avoid CR123A's AND rechargeables, and aim straight for long-runtime 4AA's, like this one, the Pelican 2410
I know, it's the incandescent forum and all that, but a camping trip with a flashlight that eats through batteries isn't really all that much fun....
I'd vote for a Surefire G2 as a good inexpensive host. Nice to hold in winter won't scratch or dent also light weight. Thats the all Nitrolon version (no metal bezel, costs less) because you don't need no metal head if you use:
a Malkoff M60 WL wich will give you 100+ lumens wich is plenty bright for general activity and also most 'tactical' stuff as everybody likes to call it!
(albeit I suppouse maybe 1-2 percent of buyers really use and need their light in a tactical way professionaly. But hey it's all about feelin' good for the costomer and marketing for the manufacturers and as long as no harm is done everyone shall cotinue to consider anything and anyone as a tactical type of flashlight/costumer. The problem is when people who really actually NEED a tactical light are buying an inferior product beeing marketed as tactical which then either fails completly or more often for the intended use: the key word here among many other parameters to consider is beeing able to operate a light under real stress, so multimode lights are generally not a good idea if you depend your life on wheter you can on/off your light instantly, everytime, anytime with one hand). But real pros should know their gear anyway one might think, unfortunately in reality flashlightwise this is not the case most of the time). Sorry but all that wannabe 'tactical' mostly marketing is hard to endure. OT rant mode off; no offence to OP, just speaking generally!).
Also as you are based in OZ I suppouse the warm tint will please you as you Aussies tend to spend a lot of time outdoors (fishin', 4WDing, hiking out bush or whatever) and the warm light really brings trees and green stuff to look good and threedimansional.
And the best thing is you get 4,5+ hours of regulated as you say ;)'tactical' runtime!:D
Got one myself and couldn't be happier!
cheers mate
Have you considered a cheaper host? If you go with one of the solarforce offerings (the l2p has HAIII ano) you'll get the light and the drop in for the same price as the Surefire.
I don't own a surefire, but have compared them to them, and genuinely couldn't tell a huge difference in the build quality, certainly not enough (for me) to justify the extra cost and inability to use 18mm cells.
Any potential reliability issues should be taken care of with the malkoff drop in anyway.
RoRo9: general purpose, camping activities, right? it's the m60LL you want in those hosts. you could also opt for the m60L, but the difference in practical UTILITY between the L and LL is not significant (i have both, i use both); if they were the same price, you'd go for the m60L, but they are NOT. the m60LL is the deal to get; an additional bonus of the LL is 6-8hrs of runtime...
don't bother with the wait for an m61; yeah it's brighter, so what? (and i got that one too)...get your equipment working NOW...
Guys thank you very much for all your help, i really appreciate it!
I think i might go for the 9P, ill go check em out at the store!
Well im off to go get em, thanks again
- RoRo9 :twothumbs
But why bother buying a cheap host that'll last you a year or two before you tire of it when you can get a Surefire that you will keep using for an entire lifetime and pass it on?
I can't really understand how you're any less likely to tire of a surefire.
Fundamentally it's an aluminium tube, the only thing to fail is the switch, which can be easily replaced.
I can see maybe surefires having a slightly more reliable switch, although I've never seen any figures for how many activations they're rated for (in either instance).
Given you can get what, 4 solarforce bodies for the price of a surefire one, I doubt they're rated for 4 times more cycles.
The only other source of failure is the drop in, which the OP stated he'd be replacing.
By all means say you prefer surefires because of the better machining (which is an excellent reason), or just because of personal preference, but reliability isn't likely to be an issue.
Most people enjoy, and, take pride in owning quality pieces of *something*. A Surefire 6P or 9P is a very inexpensive, in the grand scheme of things, piece of superb craftsmanship and quality that pretty much any flashaholic can own, should he want one badly enough.
Or, because of their truly outstanding customer service and warranty. They have rebuilt lights I've destroyed for free, and many others have had exactly the same experience.
.........I think i might go for the 9P, ill go check em out at the store!......... :twothumbs
Awrighty RoRo9, CPF is the place for the hotrod version, and that's what this would be:
- a bi-pin socket and reflector, this way bulbs are only $9, as opposed to over 30 bucks for a Surefire Light Assembly, where you throw away the refector and all every time the bulb blows...
I would pick the more available CL1499, a 7.2V lamp that when overdriven a bit will deliver somewhere between the P90 and the P91, the low and high output light assemblies of the 9P (LOLA & HOLA, sounds like they dance for money... )
- a 2 x 18500(widened 9P) body that takes the fatter rechargeables as well as 3 x CR123A's ) I would add the Z41 twistie tail switch and head option as well, there's your complete flashlight!
- last but not least, two protected 18500 rechargeable batteries and a charger from AW, he would be one of the best internet-based sellers I know!
You now have a light that last twice as long (1hr) on rechargeables, puts out a flood of light, plus the option of playing around with different bulbs, as well as extensions, in order to keep reinventing without throwing the old away.... it will also look and operate just like an actual 9P, by the way, just one with hidden powers.....
The extra cost of this light is less than what you are going to spend on batteries within the first 5 hours...., after that, all the lumens are free!
All the linked CPF suppliers are great to deal with for people outside the US, btw so is Lighthound.
Australian prices suck, you'll lose half your money that way....
Yeah...I made the mistake of buying a x-force/x-fire extension...ONCE...the threads were crap, and it wouldn't even screw onto my D3...never again...only genuine SF accessories for me (minus holsters, and stuff...)
Well in fact the diffrance is huge. I have never seen any flashlight built quality even 40-50% of Surefire. For me it is Surefire only and then there is all this other ... well I will call it low quality not to use a bad word.
I made a mistake to buy the Ultrafire flashlight for my uncle, he wanted somethig cheaper than my Surefires. The threads are so thin and delicate I'm afraid to twist the tailcap off every time the battery needs charging. The switch works when it want and does not when it should. Just a piece of c... well low quality
Yes basically it is the alumnium tube.
I don't understand why this thread has turned into SureFire vs. WhateverFire/Force - the OP had already narrowed down his selection to the:
  • SureFire 9P
  • SureFire G3
  • SureFire G2L
in his original post and wanted help deciding between the three. :ironic:
Edit: BTW he pretty much decided on the 9P way back in post #11.
  • SureFire 9P
  • SureFire G3
  • SureFire G2L
Thats probably my fault, should have known better really, and I'll leave it at that, except to say that the genuine solarforce parts are an order of magnitude better than the *fire stuff.
To get back on topic, the 9P with malkoff will be excellent, boring it out is definitely worth it, not least because you then have the option of a 6P>9P extender then using 2 18650s. This will make the light pretty cumbersome, but if you know you're going to be out and about for a long time.
You of course haven't mentioned any desire to use rechargeables, but it is certainly something you should look into (provided you use quality cells i.e ones from AW)
