CLHC
Just go buy one, or two, or three of these fine SureFire.M6s. . .Maybe, possibly the only regret is not having one. . . :wave:
1600 / 3400 = 0.47 x 60 = 28 minutes of runtime. But because the draw is slightly over 2C, I tend to burst the setup instead of allowing for continuous runs.
Cut and paste did me in this time. You are correct, post edited to reflect the correction. :thanks:....why are you setting the Bi Pin Mn socket as a requirement for the MN61 + FM 3x17670...I think it is not necessary.
Which rechargeable mod matches or exceeds the stock...MN21...
Of those 4 links above, only the bottom one appeals to me. The reason is that after messing with making a Mag85, I still consider it a novelty light, not for serious "bump in the night" type use. I had to futz around so much with getting the lamp to fit tightly in the socket and some other minor issues that I doubt I would take an M6 and do that type of mod to it. I'm always worried about flashing it and I'm told it only lives for 10 hours of use anyway. Doesn't sound like a scenario I want to find myself in with an M6.
The MN61, from what little I've learned poking around on SF's site, is a 350 lumen lamp. How is it beating the MN21? Are you overdriving it? What is the lamp life?
Yes it is being overdriven, see the chart I posted above. I have that setup and can attest to it being brighter than the MN21 on 6 CR123s.
I think AdamLau posted beamshots. Oh here found it
https://www.candlepowerforums.com/threads/193060
If someoen can make an animated gif, it might be easier to see. I did notice a difference when I went outside and tried it. I rather use a SF lamp since it is easier to swap and replace.
There is a new thread from today where a member flashed TWO expensive MN61's on 3 rested 17670's.
Yikes - ouch - ouch.
I'm going to have to sit back and this for a while.
Hi
Just a guess - but it has been observed that the MN21 causes primaries to have thermal problems when trying to do full runs and the cells die prematurely due to heat stress - looks like the graph was stopped and restarted after the cells had cooled and recovered !
Another good reason to use rechargeables such as 3x17670 +MN61
Cheers
Pete
well, MN61s aside...I've already ordered a LF-HO-M6R to compensate. for the price of two MN61s from surefire I could've bought 3 M6R lamps from lighthound
in case anyones looking for a good deal on an M6
THERES ONE IN CPFM MARKED FOR $250!
Thanks for the link to my sales thread:grouphug: Someone should be happy.
