Ryanrpm
I've read a little and many say it is the DBS v2? How far does it reach?
Over 600ft?
Over 600ft?
It depends on what light level you use as the cut off limit. A normal limit is 1 lux (moonlight). If you use that, the DBS v2 3SD Q5 SMO reaches about 180 m which corresponds to 590 ft.I've read a little and many say it is the DBS v2? How far does it reach?
Over 600ft?
jenskh the DBS will throw a beam much farther than that.
The best way to really see how far a light can throw a beam is using it in a pitch black farmers field with no moonlight. I tried this with my Olight M20 R2 and lit up objects a good 800 ft away.
The DBS will out throw the M20 anyday.
You really appreciate a light in total darkness,using it in the city never does it justice.
I think Maxabeam throws even better...I believe that MaxaBlaster wins the throw contest. Mostly HID lights are not really thrower lights, they just put out so much light, that the big HID lights will win most thrower contest anyway (Except when a DEFT is involved). But when your get to more normal flashlights, the DBS is very good.
http://www.candlepowerforums.com/vb/showthread.php?p=2372890I think Maxabeam throws even better...
Not sure which one you are referring to the Maxabeam beating. It will most certainly beat the DEFT but will not come close to the Maxablaster.I think Maxabeam throws even better...
Currently the Streamlight Super Tac IS the best and brightest thrower. Period.....No Tiablo...no Raidfire..Olight Warrior...FenixTK anything
Streamlight SUPER TAC C-4
I do not believe so, the MaxaBlaster can throw a beam 10 km, but it is also a "one of a kind" light. And as I understand it, very useful if you need to get a suntan fast (For more explanation: Read the story about how he build it).
Excuse my curiosity, but why would you want an EDC light that's such a specialized thrower? I tend to look at EDC more to the side of flexibility, reliability and portability. Such a thrower would, by definition, be unsuitable for close range, indoors, and probably unable of decent runtimes (unless it's a multimode, but even then the beam characteristics would suck at the before mentioned uses).
I'll admit some lights in my EDC rotation are decent throwers. The E2DL however has a nice low mode, and when I carry the C2+M60 I have to pair it with a BitZ (for close range flood and long runtime). YMMV, but my EDC use has a high percentage of close range work.
