My thirst for building lights with more power just could not be satisfied somehow, introducing my latest Tri led build: The "Yard Sweeper" Turbo , now over 3000 lumens.
The Tri MCE "Yard Sweeper" was running at 4.5 Amp/8V ~36 watts of LED power.
The new Tri SST-50 "Yard Sweeper" Turbo is running at 5 Amp/12V, 60 watts of LED Power :devil:
To make the light capable of handling the heat generated by 5 Amp/12V = 60W of power, Beefy copper were used for heating sinking for the head & Body by two separate pieces of copper. The host is a Copper mag 2D, that makes the total package tri copper :devil:
Specs:
Selling $325
I offer two options in the US.
PP Gift Option, Shipping & Insurance only $15. Signature may be required with insurance.
PP Goods: add 4% fee to the total.
I will ship International on this light. PP gift option only.
$20 additional shipping w/o tracking but with custom declaration #.
Tri Cree Reflector with SMO finish was used for better throw, this is added advantage for the SST, it would give donut for MCE but perfect for SST. The reflector were machined down a few mms to remove the ledge & allow fit into Mag Head.
The two piece of copper heat sinks were made:
The copper heat sink installed in Mag head with Arctic silver Adhesive:
The heat sink for the tube weight in nearly half a pound, this is after I hollowed the rear end a bit:
The heat sink for the Mag Body was jointed to the copper head sink with
concentric applications of Arctic Silver Thermo adhesive for heat transfer & JB weld for added bonding strength.
The Avnet Top bin Tri SST-50 were de-domed for increase throw.
My previous light with SST-50 de-dome have shown increase of 30% in throw. http://www.candlepowerforums.com/vb/...d.php?t=275711
De-dome have also seems to give a better & smoother hot spot with softer edge on SMO. Tri SST-50 were wired in series.
Mad 2D fit 3xIMR 26500 perfectly, tail cap recessed spring mod is a must.
Playground ~ 40 feet away
Neighbor's house ~55 feet away
Neighbor's lawn about 80 feet away
Big tree about 100 feet away
My Ceiling light is on, but you almost couldn't tell as it's over powered by the "Turbo" :devil:
Specs:
- Triple SST-50 Nutral White Extreme Top Bin Wires in series
- 22 AWG Silver coated copper wire with Teflon Sleeve
- Brand New Copper 2D mag Host
- Copper Heat sink for mag Head gluded down with Arctic Silver Thermo Adhesive
- Aluminum Tri led reflector, SMO finish for gain of 30% throw over OP
- Triple de-dome for gain of another 30% in throw over domed sst
- aluminum reflector JB welded to copper sink act as Additional heatsink
- almost half a pound of Copper Heat sink for mag Body, with Arctic Silver 5 thermo paste
- Powered by 3x AW IMR 26500, 12V total
- Dual Power resistor to modulate Amp down to just over 5 AMPS
- PVC battery sleeve/Recessed spring mod for to fit 3xIMR in mag 2D
- The heat sinking has been pushed to max copper potential
- The Power has been pushed to max spec of three SST-50s
- The throw has been max for Tri LED potential
- Huge throw and huge flood, the light is a monster!
- Beautiful & smooth tint, no yellow/no green/ no blue, just nutral white, the three leds blend perfectly together
- Beautiful beam, super bright hot spot yet smooth transition to flood very similar to SSC P4 beam, just 30 times brighter :devil:
- Do not leave it light, hold the neck/head section with your hand when it's on to transfer heat away & turn it off when your hand can't take it anymore.
- Batteries not included
Selling $325
