It takes 5.3 lbs to actuate my D10, how about you?
This seems to be a problem with AW 14500 batteries. I used an alkaline, and it took half the force (see later post). Also, the intermittent switch operation is cured by using a shorter alkaline. Often I'd switch the light on and it would go back off or directly to low mode when using 14500.
UPDATE 2:
I removed about 1/2" of wire from the spiral spring in the base of the battery tube, and more perfectly centered the spiral. When the spring is completely compressed, now there is no overlap of coils. Now it only takes 3.1 # to turn on the light with a 14500, and it isn't skittish anymore. :twothumbs
- Place a chapstick top in the middle of the platter of a digital scale.
- Press the tail button against the chapstick until the light comes on.
- Read the force from the digital readout.
UPDATE 2:
